Digital Art Zone
facial hair problem
Posted: 23 October 2012 06:18 AM   [ Ignore ]
New Member
Joined  2004-02-06
i am trying to create some facial har for genesis. here is my flow.
Daz3d: load genesis base, then hit GO-Z.
Zbrush: model the beard using extraction etc.. Hit Go-z
Daz3d: select new object then apply transfer utility. Select genesis source, target new item. Template i have tried bodysuit, and short hair,. and NONE. once it is fitted to genesis I dial in the mouth open morph and the beard does not move with the jaw. I have also tried it with the smoothing modifier. Any ideas?
Profile
Posted: 23 October 2012 09:39 AM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
In those steps, you haven’t said whether you have actually parented or fitted the beard to Genesis once it is in Studio…
If it isn’t parent/fit to Genesis, all it is doing is just hanging there and won’t move with Genesis.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 23 October 2012 03:54 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2003-10-10
mjc1016 - 23 October 2012 09:39 AM
When using the transfer utility it Parents the mesh where you put it or DAZ puts it…
 Signature
As Always B3D
My radio Station…
http://www.pandora.com/?sc=qm81447313#/
http://www.myspace.com/foleypro
http://www.michaelhershman.com
http://www.artwanted.com/foleypro
http://foleypro.deviantart.com/
http://brycepd.webs.com/
Profile
Posted: 23 October 2012 03:58 PM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2003-10-10
Also when you are in ZBrush make sure that you imbed the FiberMesh,There is an option in the FiberMesh Menu…
As for not following…I haven’t had any problems and it follows fine…Of course I imbed in Zbrush and then I make sure I have Reverse Deformations off in Morph loader Pro…
 Signature
As Always B3D
My radio Station…
Profile
Posted: 23 October 2012 03:59 PM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2003-10-10
davesolo - 23 October 2012 06:18 AM
Why wouldn’t you use Fiber Mesh instead of Topology extraction…?
Are you making a Game model…?
 Signature
As Always B3D
My radio Station…
Profile
