Every time I add a camera to the scene DAZ immediately crashes. This is easily a repeatable bug. I might need to try to add a camera 6 to 7 times until eventually it doesn’t crash DAZ. Anyone else having this problem?
I’m choosing the default position, and it crashes. It does the same with current selected view… however, if I choose the opposite from the previous crash, it seems to remedy the problem. For example, if it crashed when I chose the default view, then reopened it and chose current selected view, it doesn’t crash.
Im having the same issue, running DS 4.5.1.6 Pro 32bit and/or 64bit in OSX 10.6.8. it crashes every time i load a camera in either the default settings or applying to perspective view. seems to be a mac problem.
Can you provide the last few lines from the DS log file (if it has anything about the camera…it should, if there is a problem loading a camera…if it can put it in before the crash happens).
I have got the same problem. Everytime when I add a camera Daz Studio crashs.
I use the Daz Studio 4.5.0.114 Pro Edition on a Mac. The Mac have got a 2.3 GHz Intel Core i5 with 8 GB 1333 MHz DDR3. The operating system is Mac OS X Lion 10.7.5. Perhaps the graficcard is to bad, because it is only a Intel HD Graphics 3000 512 MB.
If it helps to analyse the problem, I can post the report after crashing.
Sorry if my english is not perfect, I am no native speaker.
Most of the time, but not all, DAZ crashes when I try to add a camera using the default settings. I boot the app and open the Lights & Camera tab. Under Editor, I select Add a Camera, and I Accept “Apply Default Settings,” at which point it crashes. I use these same steps every time to reproduce the bug but sometimes the app crashes and sometimes it doesn’t.
I’m using Version 4.5.1.6 Pro Edition (64 bit) on a MacBook Air with 2 GHz Intel Core i7, 8 GB, 1600 MHz, DDR3, Intel HD Graphics 4000 512 MB, OS X 10.8.2.
Here are a few lines from near end of the log file:
WARNING: QLayout: Attempting to add QLayout “” to QWidget “”, which already has a layout
Could not activate DAZ Decimator evaluation. Plug-in disabled.
have nothing selected when you add the camera and let us know if that works.
if it does you can thank Sean for figuring that out. http://www.daz3d.com/forums/member/2174186/
Hi StratDragon, I’m afraid that didn’t help. After booting the app, I click the background to deselect the figure, then I add a camera, and sometimes the app crashes and sometimes not. Same thing when I deselect the figure and select it again before adding a camera. The log file had the same warnings as above. But thank you, Sean, for giving it a shot.
That’s correct. When the app boots, the Genesis figure is selected by default. I can see that’s the case with the bounding box and in the Scene tab where the Text “Genesis” is highlighted in yellow. When I click on the background, the text turns white and there is no bounding box. Since nothing is selected, the Smart Content tab shows all the possible things that can be added since it’s not filtering based on a selection. Nothing else exists in the scene. There is only a Genesis figure and it is not selected.
most importantly, reboot if DS crashed at any point. Just closing and opening the app may not clear up the issue.
when you reboot hold down CMD+OPTION+p+r and the system will reboot again, do this twice, then open DS after the 2nd or 3rd reboot.
