ds 4.5 pro - where is my genX?
cosmo71cosmo71 Posts: 3,609
I have bought genX, does this not work in ds4.5 pro? I can`t find it
  • JUJUJUJU Posts: 759
    Have you searched under "window"? Perhaps you have to open that tab?
    I has had it before I updated to 4.5 and it is still there where it was in 4. First it didn't work for new morphs but GenX is updated for 4.5
  • T JaimanT Jaiman Posts: 540
    edited October 2012
    Did you put in the serial number?
    The serial is in your account under My Serial Numbers.
    Find GenX in DS4.5 Help->About Installed Plugins. Scroll down to GenX, there should be a long box to paste in the serial number.
    After you restart DS4.5, GenX should show up in Windows>Panes>GenX.
    If it doesn't, go to Edit / Customize and look under “Panes” on the left side.
    Post edited by T Jaiman on
  • SzarkSzark Posts: 10,189
    I haven't installed GenX yet but don't you have to register it first with a command in one of the main menu headings, after inserting the serial number?
    Sorry I can't be more precise but I don't intend on reinstalling it as I don't think I will need it anymore.
    If you haven't found it yet, it is under Window > Panes (Tabs) > GenX at the bottom of the Window tab. Batch Convert and Decimate are there too.
