Digital Art Zone
[SOLVED]Diamond Hair fit to Genesis
Posted: 20 October 2012 07:41 AM   [ Ignore ]
Member
Avatar
Rank
Joined  2007-09-12
I have bought Diamond Hair for V4 on sale with FastGrab and I was trying to fit them to genesis but it does not show a Fit To menu. Is there any way to fit this to genesis using autofit?
 Signature
Favourite Figure: Victoria 5
My Art Gallery: http://mattiascibien.azurewebsites.net/3d-art/
Developer of CameraReady for DAZ Studio (thesis project).
Profile
Posted: 20 October 2012 07:48 AM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
Autofit has an option for Both V4 as the donor, and Hair > Long/Short, and it should pop up itself if you try to load this item onto Genesis.  If it doesn;t, go to the Parameters tab and use the Fit To option.
It works quite well in some cases, but in others, you are much better off just scaling the hair, and then parenting it to the Genesis head.
Give it a try.
Profile
Posted: 20 October 2012 08:20 AM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2007-09-12
I cannot find Fit To even in the Parameters Tab :(
 Signature
Profile
Posted: 20 October 2012 08:25 AM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
I just looked on the Store page.  This item is a Prop hair (Poser HR2), and there aren’t any fits for Genesis, so you will have to just load it, move it into position, and parent it to Genesis.  In other words it is not conforming hair, and it will not ‘Fit To’ any figure.
Profile
Posted: 20 October 2012 08:27 AM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2007-09-12
Ok… Got It.. Thanks!
EDIT: Looks like they are perfect for my V5. Isn’t there a way to save the fit I have made and make it a follower using the utilities of DSPro?
Image Attachments
 Signature
Profile
Posted: 20 October 2012 08:34 AM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
If you roughly position and size it, you can use a smoothing modifier to eliminate any pokethrough.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 20 October 2012 09:13 AM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2007-09-12
Will try. Thank you smile
 Signature
Profile
Posted: 20 October 2012 09:59 AM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2007-01-04
To convert Prop hair (Poser HR2) to Genesis is kind of straight forward raspberry
I’m using DS 4.5.0.137 so things might be different on older or newer builds.
Load Genesis into an empty scene, making sure it doesn’t have any morphs dialed, with it selected load in the HR2 hair you want to convert, it should auto parent to the head bone of Genesis. Select the hair either in the viewport or in the scene tab, then go “Edit > Object > Rigging > Convert Prop to Figure”, in the new window make sure TriAx is selected and that you have a “tick” next to “Inherit Skeleton”, then click Accept.
You now have a TriAx figure hair, but it’s still shaped for the original figure, so still doesn’t fit Genesis.
Now start the Transfer Utility (Edit>Object or Edit>Figure menu’s), top left you’ll see “Source”, select Genesis for the “Scene item” and Clone for “Item Shape”, you’ll get a little menu showing all of the Clones you have in Genesis, pick the one the hair was designed for, to the right of those you’ll see “Target”, the scene item is your hair and the item shape you leave at Default.
Under these you’ll see “Projection Template”, click it and select the hair template that suits your hair (long or short).
Bottom left you’ll see a buttom called “Show Options” click it, now leave everything here as you see it, except “Reverse Source Shape From Target”, put a ‘tick’ in it’s box, now go ahead and click Accept.
The hair now fits Genesis, it’s now time to save it so you don’t have to go through all of that again with this hair, with the hair selected go “File > Save as > Support Asset > Figure/Prop Asset”, select where your saving the DUF to and give it a name. You’ll get an Assets save options window, with autofit or converted items I usually leave the vender name as my own, the Product name I put the original vender’s name and the Item name is the product’s name, this way all my converted items are out of the way, and I still know who the original vender was.
 Signature
**shuffles of with a new headache** tongue wink
Profile
Posted: 20 October 2012 10:53 AM   [ Ignore ]   [ # 8 ]
Member
Avatar
Rank
Joined  2007-09-12
Did everything and DAZ Studio… Crashed. Sending bug report now.
EDIT: Ticked the wrong box.
EDIT2: Worked like a charm.
 Signature
Profile
