Digital Art Zone
DS4.5 Shader Mixer - What’s happening with the normals here? SOLVED
Posted: 20 October 2012 06:13 AM   [ Ignore ]
Member
Avatar
Rank
Joined  2007-09-01
SOLVED: The output of a Normal Map brick is NOT a tangent-space normal (which is what I thought). It’s the normal in camera-space after it’s been applied to the object. And by the way, camera space uses a left-handed axis system with the camera’s line of sight being the positive Z axis, so normals for ‘forward’-facing faces will have negative values.
I’ve run into a curious problem while trying to combine normal maps with DS4.5 Shader Mixer. I’ve managed to reduce the problem to something (hopefully) quite straightforward. I’ll start with the bit that works fine.
The four brick network shown here simply takes a normal map, splits it into it’s components and recombines them.
I’d expect this to work, and it does.
Image Attachments
 Signature
Website: UnrealImperfect | Freebies: Renderosity, ShareCG | ‘Art’: DeviantArt | Blog: Blogger
(after a brief try-out of username ‘unrealimperfect’, I’m back to ‘3dcheapskate’)
Profile
Posted: 20 October 2012 06:14 AM   [ Ignore ]   [ # 1 ]
Member
Avatar
Rank
Joined  2007-09-01
Since a normal is just a unit vector, it should be easy to calculate the third component (Z, blue) from the other two (X, red and Y, green) using simple trigonometry, B = SQRT(1-((R*R)+(G*G)))
(No, there’s not really any point in doing this, but it’s just the simplest way I found to explain the problem)
That’s what this next network does. (The three bricks in the bottom right are simply to verify that the calculated Z(blue) value matches the Z (blue) output of the splitter brick - it does)
I would expect this network to work too, but it doesn’t!
(Edit: discovered an even simpler demonstration of the problem - see the fifth post (#4) for the network I used)
Image Attachments
 Signature
Profile
Posted: 20 October 2012 06:14 AM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2007-09-01
Here’s the results when you apply the two networks to a sphere primitive (I also tried applying plugging the end result into the Diffuse Color input of a Surface brick, and noticed the difference there too - I include those renders as they may provide a clue).
The renders on the left are from the first network and are as expected.
The renders on the right are from the second network, and I can’t understand why they’re so different.
Image Attachments
 Signature
Profile
Posted: 20 October 2012 06:28 AM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2007-09-01
I’ve got to the banging-head-against-the-wall stage with this one.
An explanation as to why on earth the second network behaves so differently, even though the inputs to the final Point brick are to all intents and purposes the same, would be greatly appreciated.
More background in my Simple Material Mixing With DS4.5 Shader Mixer thread.
 Signature
Profile
Posted: 21 October 2012 01:18 AM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2007-09-01
I’ve just discovered an even simpler demonstration of the problem - take the ‘Z Component’ output of the ‘XYZ Components’ brick, multiply it by itself, take the square root (so you should end up with the same value as the ‘Z Component’ that you started with) and plug that into the ‘Z Value’ input of the point brick.
That should definitely work, shouldn’t it?
It doesn’t!
I get the same effect as the network in the second post (i.e. renders like the two images on the right in the third post)
To me this makes it clear that it’s not faulty maths that’s causing the problem!
Image Attachments
 Signature
Profile
Posted: 01 November 2012 11:06 PM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2007-09-01
(Addendum: thanks to millighost over in this Renderosity forum thread for the enlightenment)
 Signature
Profile
Posted: 05 November 2012 12:20 PM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2005-01-19
3dcheapskate - 01 November 2012 11:06 PM
Thanks. I didn’t understand why I obtain results with negative normal and not with positive. I didn’t think about changing axis when space is changed.
 Signature
Playing with shaders
http://www.daz3d.com/forums/viewthread/20283/
Profile
Posted: 05 November 2012 04:29 PM   [ Ignore ]   [ # 7 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
A lot simpler explanation than what I was working on when I lost power for 4 days…
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
