Digital Art Zone
Applying A3 texture on Genesis [solved]
Posted: 20 October 2012 05:34 AM   [ Ignore ]
New Member
Joined  2008-08-24
I’m trying to apply the Kirei no Kanjou for Aiko 3.0 texture to Genesis but it doesn’t seem to be working. I have GenX, A3 Iconic Shapes and I even got TextureConverter but I can’t seem to use the converter right.
When I convert kirei and try to apply it using the Surfaces tab it gets messed up. I put the converted mat as a Diffuse map. Is this correct?
Does anyone know of any tutorial on how to convert/apply A4 textures into Genesis?
Profile
Posted: 20 October 2012 05:48 AM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
In the Surfaces Pane what is the Uvmapping set to? If all went well you should have a A3 option to choose. If you have this option then choose A3 and look for the little padlock beside the UVmap channel and Lock it. This will ensure it doesn’t slip of. If you want to change the textures then you will have to unlock the Uvmapping.
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 20 October 2012 06:12 AM   [ Ignore ]   [ # 2 ]
New Member
Joined  2008-08-24
I don’t see A3 under UV set. I see V4, M4, Genesis M/F and The Kids. Where do I get the A3 UV Set?
Profile
Posted: 20 October 2012 06:20 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2007-01-04
You wont find it, Gen 3 textures don’t work on Genesis, you would need to use something Texture Converter to turn them into a Gen 4 texture.
 Signature
**shuffles of with a new headache** tongue wink
Profile
Posted: 20 October 2012 06:28 AM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Bejaymac - 20 October 2012 06:20 AM
What even with GenX for A3…humm that is news to me, thanks. So it is only for Clothing and morphs then, not textures.
Sorry about the incorrect info, my bad. I don’t bother with GenX anymore but I thought it did texture maps too.
 Signature
Pete
My Render Thread
Profile
Posted: 20 October 2012 07:52 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2007-01-04
AFAIK GenX is just for transferring morphs from one figure to another (I only have the old Gen4), to get Gen 3 maps to fit Genesis would require a remap of the UV’s but it would also need the Surface Groups in Genesis to be redone to match the Gen 3 Material Zones, and this can only be done with a second Genesis as those changes can only be stored in the main figure DSF, so do that to the main Genesis and you wont be able to use any of the Gen 4 or Gen 5 textures any more.
 Signature
Profile
Posted: 20 October 2012 07:54 AM   [ Ignore ]   [ # 6 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
So we can’t use Map Transfer then to do the job?
 Signature
Pete
My Render Thread
Profile
Posted: 20 October 2012 08:51 AM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
No, UVMap switching can’t change the material zones, just which vertices get assigned to each zone, so it doesn’t work for Gen 3 textures.  When you tried Texture Converter 2, were you converting A3 to V4?
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Profile
Posted: 20 October 2012 09:00 AM   [ Ignore ]   [ # 8 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Darn you Mike you beat me. Convert your A3 textures to V4 then they will load on genesis.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Profile
Posted: 20 October 2012 09:29 AM   [ Ignore ]   [ # 9 ]
New Member
Joined  2008-08-24
Ok. I got it to work. Thanks guys!
Profile
Posted: 20 October 2012 09:55 AM   [ Ignore ]   [ # 10 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Interesting stuff. I don’t have A3 and Texture Converter hence me asking questions.
 Signature
Pete
My Render Thread
Profile
Posted: 23 October 2012 02:49 PM   [ Ignore ]   [ # 11 ]
Member
Avatar
Rank
Joined  2006-09-05
Does it had the eyebrows mapped on the skin texture too? Genesis does not have them…
 Signature
http://mcmxc2.deviantart.com
Profile
