Looking for tutorial
LazarusziLazaruszi Posts: 0
edited May 2012 in Carrara Discussion
Hi!
My question would be that someone could make a tutorial or example of how such an object emitter upload?
Thanks in advance for your help.
example: http://www.youtube.com/watch?v=iUcEEKtUnZc
Post edited by Lazaruszi on
  • 3DAGE3DAGE Posts: 3,311
    HI Lazaruszi :)
    Since it's my clip, I better explain how I did it :)
    It's a trick. / illusion.
    Carrara particles have NO Volume,. they're flat, and don't build up. ...so,. you need to fake it.
    The Glass has an object inside it (the fluid) and that object has a couple of Morphs, to make it "Fill Up" the glass.
    the main particle emitter, uses a "Meta Particle" which looks like a fluid / liquid. and the particles collide with the glass.
    The "fluid" object in the glass, is animated to change the morph and "Fill the glass".
    Hope it helps :)
  • LazarusziLazaruszi Posts: 0
    LOL Thanks for the quick reply :) I will try to do the trick :)
    edited May 2012
    Then I can not do such a thing with carrara?, just Blender or RealFlow?
    example: http://www.youtube.com/watch?v=P0PKkE8awcw
    Not yet :)
    There's a system being developed by Frederic " F1oat " , a user here. and there were some interesting examples shown in the old forum, but .. I've no idea where those are now.
