What's like the best option to export file from Daz to Carrara pro8?
lord Adamlord Adam Posts: 125
Hi folks!
Today I just wanted to export figure with clothe&hair; from Daz to Carrara (as COLLADA file)but during that process I get only errors... What's like the best file format for Daz figures??
I tried some, for example I lost all textures if I export figure as simple OBJ file...
  • DartanbeckDartanbeck Posts: 21,187
    I'm not sure that Genesis works with Collada, and I know that it won't work in Carrara 8, only 8.5
    For Carrara 8.5, the best way that I know of is to save as a duf character or scene.
  • OldminerOldminer Posts: 134
    In 8.5 if you open a DS 4.6 duf Carrara brings in everything - lights, cameras etc also if your figure has a lot of morphs you may have to do some tweaking otherwise it works pretty good.
  • 3DAGE3DAGE Posts: 3,311
    Hi Herkules80
    The easiest option is NOT to Export or Import..........
    Carrara can load your Daz-3D figures, clothing, hair, materials etc,. directly into Carrara,
    If it's a scene you've made in Daz Studio, and you want that in Carrara,. ... Save the DS Scene as a DUF format, and Carrara 8.5 will open that.
    The best work-flow is to Begin by loading the Content (figures models etc) into the program you want to work with,.
    Carrara has always had the ability to load "Content" directly from the Browser window,. whether that content was originally designed to be used in Carrara, or Poser, or Daz Studio, or most other 3D model formats. So,. you can Open Carrara, Load your figures and props from the Content browser, or Smart content browser.
    Hope it helps
  • lord Adamlord Adam Posts: 125
    There is no such thing like: DUF format - option on the list: save file as... in DAZ Studio 4 or maybe I'm blind?
    By the way: what does it mean a DUF shortcut??
    2000 x 1015 - 248K
    You are using an older version of DAZ Studio, before the DUF file format was first used.
    You would need to upgrade to at least DS4.5 to see that. The latest version of DAZ Studio is 4.6.2.118 and should be available from your My Account > Product Library area.
    I just installed the latest version of DAZ Studio 4.6 and there is DUF option, thanks
    but now I've got a new problem: where I can find Carrara pro 8.5 32 bit?? (I' ve got win 7 and Carrara 8.0). In the web there is only software for win 64 bit...:(
    edited March 2014
    Carrara 8.5 is the 32 bit version, 8.5 pro is the 64 bit version, as shown in the product library. Just use the carrara pro serial number to get the pro features for the 32 bit version.
    Post edited by Chohole on
  • evilproducerevilproducer Posts: 9,040
    Just to be clear, if you bought 8.5 Pro, you should have the 64 bit version and the 32 bit standard version in the account to download? Also entering the Pro serial number into the Standard 32 bit version unlocks the Pro features in the 32 bit Carrara?
    Sorry, was my explanation a bit garbled, I guess it has something to do with the half bottle of wine, my half of the bottle I just shared with himself.
    edited March 2014
    Not garbled. I just thought a bit more info. would help. If all goes well over the next few weeks, I may be able to get C8.5 myself.
    Ah good. I am glad it wasn't the fault of the wine. We rarely drink nowadays because himself is on warfarin and alcohol is not recommended as an accompaniment to his daily dose of rat poison, but we do like to have a couple or 3 glasses of wine after Sunday Dinner, is our weekly treat.
    If you are not drunk the following should be easy to read and make perfect senc•: Kpp e[jf= ©π‘]=-30] “‘™∞¬;'jdp[ pjd039!! ;-)
    edited March 2014
    Hic pardon ? I'm not as think as you drunk I am
