Image on a Plane
I'm not able to display an image on a plane primitive. I'm trying to add it throug hthe Srufaces tab in the Diffuse Color section, it appears there, but not on the actual plane, Do any others settings have to be adjusted?
  • JaderailJaderail Posts: 0
    Is your Diffuse Strenght set to 100%? I can get an image easily. Also you will need a light on the Front of the plane for the image to show. If your lighting is behind it the image will not be visable.
  • edited December 1969
    If the sizes are off, is there a way to stretch or shrink the image to fit?
    edited July 2012
    Just shrink your Plane with the Prameters Tab, X and Z scale I belive.
    P.S. Square images are the best to work with. But a 2D art program is handy for editing your Image file.
    Post edited by Jaderail on
    I still got nothing. I tried jpg, png, bmp, all different sizes, added lights, rotated and resized the plane and it's still gray.
    edited July 2012
    How are you doing this? Create Primative Plane. Select Plane in Scene Tab. Open Surfaces Tab. Open Default Diffuse, use Drop down arrow to browse to image. Add Image. My steps.
    I'm in DS4Pro what are you using.
    EDIT: Diffuse Color to add the image.
    Yes, I did everything you did. I have 4.0 pro 64bit. I just tried rendering and it DOES show, but for some reason not in Studio... is that normal?
    That might be a issue of your Graphic Card. But I'm not sure. Do you get textures on other Items like Genesis?
    All other textures seem to work fine. As long as it renders fine I guess it's OK. Thanks for the suggestions.
    FYI: I have an HP laptop with an Intel Graphics Media Accelerator 4500MHD w/ 2 MB of video memory.
    Okay, But I'm still puzzled.
  • TapiocaTundraTapiocaTundra Posts: 268
    edited July 2012
    I know it might be obvious, I am new with Daz Studio, you have to have the draw style set to texture shaded, I have made that mistake.
    Post edited by TapiocaTundra on
    You win the prize! Somehow I had it set to smooth shaded! :red:
    Ha,, It was no "surprize", n I like prizes :)
    Well I'll be, never crossed my febble mind to ask about the draw style. DUH!
