discoloration on legs
benjbernstein
I was hoping someone could help me with this. This is Brooke for V6. I'm using Poser 10 on Mac. I've tried adjusting the lights. Nothing in the material room looks like it's out of place either. Any ideas?
Right off hand, it looks like either the texture maps are applied to the wrong body parts, or are trying to use the wrong UV maps.
are you using DSON to be able to use V6 in poser?
I'm not really sure of what your question is. I'm pretty new to this so I may not follow you exactly. I do have DSON installed and I've used it to install a few figures. This particular figure Brooke, from Digital Creations was installed by downloading the file and then I copied the file to a folder (I forget if it was the Daz or Poser folder). genesis 2 was installed via DSON and I can't remember if V6 was installed using DSON. The reason I didn't use DSON to install the Brook character is becasue it didn't show up on the download or ready to install tabs so I just copied and pasted.
i guess what I'm asking is - her textures don't look right to begin with?
Yeah, that's pretty much how she looked when I put her into the scene. I thought maybe it would change after I rendered but no. So you think it might have something to do with the file?
if you have DS - open her up in there and check her uv maps, make sure they are either Base female or victoria 6 (whichever one makes the texture maps sit properly) and if you have to fix it, let the vendor know so they can check also.
i only found a brooke for victoria 4 - (here at daz)
Do you have the V4 Shape for Genesis 2?
http://www.daz3d.com/victoria-4-for-genesis-2-female
From the product description, I believe the texture is actually for V4 and there are shape presets for V4,V5 and V6. If you don't have that product, then the texture will not work on Genesis 2/V6.
True MM3 i had forgotten about needing V4 for genesis 2 female .... makes sense now.
Yup, I had to buy V4 for it. I'm going to try to load again from scratch and see what happens.
I reloaded and this time it looks like the lines were gone but the lower half of the body is still a different color than the upper body. So not sure what's going on.
