Grand Piano?
SickleYield
If someone already knows of one of these, awesome.
So far the only grand piano I can find with Google, ShareCG, Rendo and on DAZ is this one: It's super old and doesn't look that great. There have been a few uprights made, including by VanishingPoint at Rendo, but I can't find a good classic grand.
Post edited by SickleYield on
http://www.daz3d.com/shop/the-mansion-music-room/
http://contentparadise.com/productDetails.aspx?id=3324
http://www.turbosquid.com/FullPreview/Index.cfm/ID/444507
http://www.turbosquid.com/3d-models/grand-piano-seat-3d-3ds/485880
http://www.turbosquid.com/FullPreview/Index.cfm/ID/544253
http://www.turbosquid.com/3d-models/grand-piano-3d-model/576809
http://www.turbosquid.com/3d-models/piano-3d-model/538995
You were saying?
Normally I wouldn't consider a morphless noncompatible file format from Turbosquid, but on the other hand, one of those is free and comes with an obj.
Thanks.
3ds and lwo files are very easily converted and you did not ask for any morphs.
And both the models linked at the DAZ and CP store are posable.
Say what you actually want and do not rely on people trying to read your mind.
This one at Renderosity free stuff isn't bad, allowing that it has no morphs, so closed is all you get. There's also this low poly piano, but I haven't used that one, so I don't know how well it works. For what I wanted I wound up using the first one (because, come on: candelabra!) and this piano bench, which does have morphs. (Which, it turns out, are seriously annoying because it's very easy to accidentally select the top of the bench instead of the whole thing.)
Hope this is useful.
http://www.ShareCG.com/v/55755/view/5/3D-Model/model-d-grand-piano-with-bench-in-.obj
http://www.renderosity.com/mod/freestuff/details.php?item_id=65900
lowpoly 88key d model grand
free for non commercial use
I see. What I should have said was:
Has anyone seen a medium- to high-poly grand piano made in the last couple of years in .pp2 or .dsf format with a closed-lid option and DAZ mats?
And the answer would be: No. Then I would logically conclude that the only way to obtain the item I want is to build my own. This is not a bad idea anyway, really.
Thank you to the others who responded.
