Carrara 8.5 and Windows 8 Pro
GKDantasGKDantas Posts: 200
Anyone with problems to run Carrara 8.5 64 bits in Windows 8 Pro? It install without problem but I got to error messages when open Carrara:
CR2Importer.mcx failed to load!
Carrara open fine after hit OK button, but when I try to add a Runtime folder I got this new message:
A nil pointer error has occurred.
File: BrowserDialogFamily.cpp
Line: 58
So I cant add none ordinary Runtime even SmartContent
Carrara 8.1 32bis working fine here...
  • edited December 1969
    I am having the same problem as you, did you find a solution? Thanks
    [email protected]
  • evilproducerevilproducer Posts: 9,040
    It's the weekend so things will be a bit slow. I'm sure you'll get the help you need though!
    I would help myself, but,
    A) I don't have C8.5 yet, and
    B) I'm on a Mac.
    At least the topic is bumped!
    Good luck!
  • Subtropic PixelSubtropic Pixel Posts: 2,378
    edited September 2013
    I have 8.5 Pro and Windows 8 Pro.
    It's not clear in the original post if this happens upon launching Carrara or if the error arises when you do something specific.
    If you give a step-by-step method of reproduction, I'll test it here.
    EDIT: Whoops, I just noticed that the OP was in 2012. It's obviously not related to Windows 8 Pro...
    Post edited by Subtropic Pixel on
    To be honest I doubt if the query is still live or pertinent, as the OP has posted several quite a few times in other places, since he made that post, but has not revisited this particular thread.
    I think the post that bumped the thread was either an unfortunate one or it was bumped for some other reason.
    Post edited by Chohole on
    Aak! Maybe the second post was spam?
    I didn't even look at the date of GK's post.
    Time to fill the zombie thread with kitties or zombie kitties!
    Or a failed spam attempt, thawted by the software.
    Not sure I have too many zombie lolcats in my collection
    500 x 333 - 31K
    :lol: :lol:
