Forest Bundle Question
TallulahdahlingTallulahdahling Posts: 372
I'm interested in getting the Forest Bundle by Andrey Pestryakov,
In the "additional information" box it says that this product is compatible with Poser, and I'm assuming that means all the Posers because it doesn't specify any versions.
However, when I looked at all the images, some of them have "For Daz Studio and Poser Pro".
That's a bit of a worry. I have Poser 7, not Poser Pro. Will the bundle work for me? Will it work, but some feature or other won't?
  • SpitSpit Posts: 2,163
    It should work in Poser 7 but the forest loads in all at once so the problem will be its size. The couple of gigs available in 32-bit programs such as Poser 7 is limiting. I wanted it so bad when it came out but I waited until I got a new machine. And even though it loads fine for me and all, it's still slow trying to move around.
    However, if you load it up you can find the trees that aren't in your view and either delete them or make them invisible though I don't remember how to do that in Poser (been a long time).
    It's really a beautiful set and his trees are superb (the autumn and winter ones are textures for The Forest which is required.)
  • Andrey PestryakovAndrey Pestryakov Posts: 140
    Yes requires Poser Pro (64 bit).
    Poser (32 bit) can not render a picture it does not have enough memory, because forest scene is very big.
    edited April 2013
    Please look at the possibility of OctaneRender for DAZ Stusio.
    Forest + Forest Superior.
    More details http://www.daz3d.com/forums/discussion/20589/
    1920 x 1080 - 692K
    1920 x 1080 - 688K
    Post edited by Andrey Pestryakov on
  • TallulahdahlingTallulahdahling Posts: 372
    Thank you, everyone, for your input.
    Andrey, since I made my original post my old PC died for good and I had to get a new one - 64 bit. I decided to learn DAZ/Studio 4.6 because I wanted the advantages of Genesis (without having to shell out a lot of money for the latest Poser), since I specialize in children and need to have some child versions of certain adult characters. So now I should be able to enjoy your beautiful forest!
    Thanks for the information.
  • patrickgobelspatrickgobels Posts: 477
    Has the Forest Bundle already been on a special sale this month? *drooling on the keyboard*
    Unfortunately I do not know. It is better to ask this question the administration DAZ3D. ;)
  • cosmo71cosmo71 Posts: 3,609
    from somewhere inside the forest superior rendered just with one distant light and deep shadow map :) rendertime 15minutes
    1800 x 900 - 283K
