Pyrit Hair: MAT Poses not being applied
Hi;
I just purchased the Pyrit Hair and the color pack.
The colors are not being applied
When I go into the material room and try to apply them part by part (by clicking the Mat pose) the change doesn't persist. Meaning that I will apply front 4 to the front pieces, but when I go back to check, they've reverted to the default texture.
I'm using Poser Pro 2012. I've never seen this behaviour before.
Please help, I need her to be blonde!
Thanks!
  • LycanthropeXLycanthropeX Posts: 2,287
    I don't have the hair, can you show some screen shots of the problem?
  • edited December 1969
    I wouldn't know what to screen shot. Here are the steps:
    Select Pyrit Hair model. Click on MAT pose.
    Nothing happens.
    Open up Material Room.
    Select part Hair 3 Front. Click on MAT pose and see that it is applied.
    Select parth Hair2Front Click on MAT pose and see that is applied.
    Click on Hair3Front again and see that the original texture is there
    Ditto Hair2Front
    Manually applying the texture works.
    i wonder if maybe you missed an installer, maybe it was in 2 parts
    i just got this set, you are right, the mat poses do nothing, there are no materials in the materials library
    These seem to be fixed now, reset your downloads and reinstall
