How to scale Romany Charm set? {solved}
WillowRavenWillowRaven Posts: 3,724
edited July 2013 in The Commons
The setting is too big compared to v4/m4, and I can't simply rescale v4/m4 to fit beacuse then the dynamic clothing won't fit. Problem, though, I don't see how to scale it.
Help?
Post edited by WillowRaven on
    edited July 2013
    Should just be a simple scale setting. If the set has separate props for the interior, parent them to the main section before scaling and all 'child' entities will scale down accordingly. If the scale option is missing then ensure sure you make hidden controls visible in the options.
    Post edited by Herald of Fire on
  • WillowRavenWillowRaven Posts: 3,724
    That made the dial appear, but even though parented, nothing re-scales at the same rate.
    Try adding the item to a null and then scaling the null. I find this works wonders in situations like that.
    So how do I do that?
    Create -> New Null
    Parent the item to the null and then rescale the null. Sometimes you find that it's not the scaling which is the issue, but the positions not changing so that they scale in place. This means that when the object shrinks or expands, items essentially seem to move from their original spots.
    Create -> New Null
    That did the trick, thanks :D
    Glad to be of help. If you edit your original post you can put a [solved] tag on the end to indicate that all is well :)
    Done :D Thanks, again :D
  • JaderailJaderail Posts: 0
    The Solved was Noted and very much appreciated my this Mod. TY for being so kind as to do that. TY also HOF for the suggestion.
