Is there atutorial on how to use the Victoria 4 for Genesis 2 product???
Luv LeeLuv Lee Posts: 229
One of the many reasons I never upgraded to genesis is because I do numerous anmated shows and comics using old gen 4 textures, so when I saw the Victoria 4 for Genesis 2 Female product I was ecstatic and bought it immediately--downside--there are no tuts and I have no earthly idea where to find the things I need to apply to the genesis 2 character and no idea what to do even if I DID locate the materials. Also, when I tried to turn an old texture V4 preset from a PZ2 into a DUF as per request of the product maker, it just made the file unusable ( it read an error when I tried to apply it to genesis 2). Is there any info out there on how to use this product? I am pulling my hair out.
Post edited by Luv Lee on
  • BlackFeather1973BlackFeather1973 Posts: 739
    Here's the steps i took to apply the Misu V4 texture to Gns2F
    * Load both V4 and Gns2F
    * Apply the texture to V4
    * With V4 selected, File -> Save as -> Material(s) preset
    * Select Gns2F and apply the new material preset you just created
    * In the Surfaces tab, select 'Genesis 2 Female' and change the 'UV Set' setting to 'Victoria 4'
    All done...
  • Luv LeeLuv Lee Posts: 229
    Thank you so much sweetheart--I'll drop a line after I try it--you're the best!
    All done...
    worked like a charm, thank you so very much--may I ask another quick question--how do you apply a character preset as well? Thanks again so much...
    Alicia
    Afaik Genesis2 won't accept shaping presets from previous generations, although there is a way to convert morphs to Genesis2, see this thread.
    Genesis use V4 UV mapping by default. You can use all V4 textures on it.
    But Genesis2 doesn't.
    Ah thanks again so much! I appriacate your assistance....
    Alicia
    Yeah, I kinda noticed that when I was playing around last night--doh! Could have been experimenting all along--I am gonna play a bit today to see what kind of stuff I can come up with....you guys have been wonderful--I humbly thank yah :-)
    Alicia
