P-51B/C in 3DS (fantastic model!)
wancowwancow Posts: 2,708
edited April 2013 in Freebies
http://www.turbosquid.com/3d-models/north-american-mustang-fighter-3ds-free/416157
Unfortunately for me, I can't seem to get the textures to apply properly in Hex... and it comes into Blender all... it doesn't like Blender... hmmm...
It's in 3DS format, two meshes, one flying one on the ground. The modelling is fantastic... the UVS are the problem...
Post edited by wancow on
  • BWSmanBWSman Posts: 0
    You should try PoseRay to convert from 3DS. It should do a good job of keeping the UVs intact. The only issue I (personally) have with PoseRray is that it changes the mesh to triangles when converting to OBJ format.
  • wancowwancow Posts: 2,708
    edited April 2013
    That worked!!! Thank's for that tip! 3DS is usually triangles anyway.
  • English BobEnglish Bob Posts: 79
    PoseRay makes everything into triangles, unfortunately. Anthony Appleyard's Detriang usually does a reasonable job of converting back to quads, although the resulting topology might not be very elegant... ;)
    You can find it in Renderosity Freestuff
  • MattymanxMattymanx Posts: 6,283
    Why waste your time if you can just go here - http://www.colacola.se/map_1.htm - and get already Poserized WWII planes
    Because that's a P-51B :)
  • Joe CotterJoe Cotter Posts: 3,234
    And while it's great stuff it is also non-commercial, which may make them a no starter depending on intended use. I notice he put up a new model and a nice about page. I didn't realize he was lead artist on 2 large commercial projects, or that he'd been published that much. :)
  • AscaniaAscania Posts: 807
    So? This is a .3ds. It already IS all triangles.
    I could be wrong but I gathered he meant that as an aside for anyone converting meshes that might not be triangles already...
  • scathascatha Posts: 756
    edited May 2013
    http://www.sharecg.com/v/44695/gallery/5/3D-Model/P-51B-Mustang
    Packed and ready for poser, works in DS too.
    Many more airplane models available from this modeller.
    Post edited by scatha on
  • UVDanUVDan Posts: 112
    Two thumbs up on Neil's airplane models. They are made for Poser and sometimes take a tweak or two in DS, but they are great models.
  • WandWWandW Posts: 2,194
    The TurboSquid model linked to on the first post is now in Carrara format...
    Hey Dan, long time no see. :)
    I have to agree, Neil makes very good models and they are more accurate then many paid models I have seen in stores.
