color shift importing photoshop file
bobalinkbobalink Posts: 0
edited December 1969 in Bryce Discussion
Can anyone tell me why when I import a png, tiff, jpg file from photoshop the colors are completely different?
  • David BrinnenDavid Brinnen Posts: 3,136
    First things first, Mac or PC?
    Also, can you upload a screen grab of the before and after?
    If you are on a Mac, then this thread may help you
    http://www.daz3d.com/forums/discussion/19947/
  • bobalinkbobalink Posts: 0
    I'm on a mac using 7.1.0.74
    I attached a photoshop file I just made of 3 boxes of red, green, blue
    and a screen grab file of Bryce and as you can see the colors aren't
    close.
    (I can't figure out how to attach 2 files so I will post the Bryce file next)
    I also have a PC with Vista, are there these color problems on a PC too?
    thanks, bob
    733 x 570 - 12K
    Here's the Bryce file of the photoshop 3 color boxes
    619 x 352 - 167K
    No this is a known Mac issue. If you switch to PC, even if just for the import of the images, then you should be OK.
    Thanks so very much! Just wish I stopped by here before spending a bunch of hours trying to get it to work.
    So are you saying if I use a PC and import the 2d file, I can then use that file to open on a mac and the image of the 2d will remain the correct color? What file format does Bryce like the best?
    Thanks again!!!
    Yes, though I don't have a Mac to test this on, that is what I understand the case to be.
    I import images as bmp and jpg mostly. They seem to work fine on the PC. There is no internal image compression in Bryce and I believe all jpgs are uncompressed once imported, so there's nothing to be gained by using highly compressed images.
    Did you try Dan's tip, in the thread I linked to. Of course that only works if you are using DS and the bridge.
