Carrara graph editor help
SonofbelmontSonofbelmont Posts: 67
edited February 2013 in Carrara Discussion
Hi
The graph editor in Carrara always seems to be so squashed (or stretched I'm not quite sure which) that pretty much all my curves look like flat lines unless I zoom right onto a single key at which point I can't see any of the other keys
is there any way to reduce this effect?
also how to I change the default interpolation for keys to be smooth instead of linear?
any help would be appreciated
thanks
Post edited by Sonofbelmont on
  • wcwilcoxwcwilcox Posts: 0
    To change the graph size select the graph editor.
    SEE IMAGE#1
    To change the interpolation use the tweener to change settings.
    SEE IMAGE #2
    1242 x 556 - 104K
    1280 x 800 - 184K
  • evilproducerevilproducer Posts: 8,998
    Hi
    thanks
    For the Graph editor, have you used the little blue widget between the Timeline and the scene window? You can expand the editor upwards (and squash the scene window) to view it better. You also mentioned the zoom tool. You my have better luck with it if you expand the timeline window upwards.
    To set the default tweener, go to File-->Preferences and use the pulldown menu to select General Scene Settings. At the bottom of the window it should say, Tweener and give you a pulldown menu with a list of available tweeners. From what you describe, it sounds as if you want Bezier.
    673 x 503 - 28K
    573 x 800 - 87K
    497 x 229 - 15K
    Curse you wcwilcox! You beat me to it! Darn my slow pudgy typing fingers! ;-)
    Sorry man. But you did gave a much better explanation.
    Just kidding ya'! ;-)
