Has anyone come across this?
Hi Daz friends,
Today I'm unable to get into Daz for some strange reason.
Has anyone seen this comand?
I've tried to tried to "restore" to an earlier time but my back up was 3 months ago..yeah crazy
Hoping it's a small problem and I havent lost everything
Have a look at this thread and see if it helps any : http://www.daz3d.com/forums/discussion/7905/
You're missing an important file from the content management service. The CMS is used to run the Smart Content in Daz Studio. You should be able to simply re-install Daz Studio to fix this. Your content library won't be affected, but you might have to re-import any existing metadata.
Thanks Jimmy and thanks again Herald,
I'll give both a shot,as you can imagine i'm in a bit of a panic
And yes Jimmy came across the "child killed" command..that was an odd one
It's referring to a sub-object within a container rather than a young humanoid. Although best keep it away from your kids just to be safe...
Yes, a particularly nasty expression, it always makes me cringe when I see it.
Haaaaa,yes I've been called many things but not a child killer!
Just a simple girl,down under who panics when my Daz file explodes...jeez
Like I said thanks for the help..your often too scared to start messing around with things
Yep,I'm still "killing children"...I'll have to take a slow indepth look at the thread you've linked
Jimmy!
Herald!
Back in the world feeling good about myself..it's working after a time consuming process.
Thanks for your time and knowledge..you've made my day
