How to install, and select Victoria 4.2
MrCedricMrCedric Posts: 25
Hello
First of all, as a newbie, sorry in advance for my common question. I have tried different things found into your forum, but with no success. I certainly missed something…
So, I installed your free Daz3d app ( thank you ! ) and it works great, I'm half-way now ;-)
Then I bought from you Victoria 4.2 Base, unzip it, and then my problems begun…
- I have tried different folder to put in V4 : Runtime/Library/etc…
And when I open DAZ and try to load/place in the scene Victoria 4 I can't, I don't find her on the left menu with Genesis/Kids, so I tried via the right ones, on this way I can apply some poses but when I want to double-click on Victoria4 to apply her on the standard 3d model on the scene a window appears telling me no way…
I'm planning to use and buy a lot of nice things that I saw on your shop, so I really want to understand correctly after buying how and where to put this different files folders to be able to work with…
I hope my french/english is not too hard to read ;-)
Thank you in advance !
C.
  • frank0314frank0314 Posts: 13,354
    Are you on a Mac or PC? If on a PC you need to be installing it into C:\Users\YOUR NAME\Documents\DAZ 3D\Studio\My Library
  • MrCedricMrCedric Posts: 25
    I'm on a PC. So I just need to move with drag and drop Victoria4 folder into MyLibrary?
    Extract the zip into that folder. It will put it where it needs to go
    Great, it works now! Thank you very much ;-))))))
    edited January 2013
    Just a last question... When I bought Victoria, 2 other files are downloadable : a "Victoria Power loader" and a "Victoria DS poses", but this files seems to failed at the end of their installation, are they important?
    Post edited by MrCedric on
  • Richard HaseltineRichard Haseltine Posts: 96,731
    PowerLoader gives you a dialogue when you impotr the figure, so that you can choose which morphs to load, apply a material set, and adjust scale and subdivision. The DS poses are just that - a few poses, and I think a Puppeteer preset or two.
    If it failed at the very end of the install, then they are perfectly installed...the part that fails is the documentation/links writing.
    Thank you guys ;-)
