JavaScript seems to be disabled in your browser. You must have JavaScript enabled in your browser to utilize the functionality of this website.
I'm using 4.5.1.6 64 bit
I ask because I cant get collada export to work
There is a new release (2 weeks ago), the current version is 4.5.1.56 and it is in the Store.
There is a thread about it, I'll see if I can find a link for you.
EDIT:
Here is the link to the thread : http://www.daz3d.com/forums/discussion/14562/
Thanks a lot!
I've never actually looked at the version numbers properly - so I was thinking the.1.6 bit was newer than 1.56 ..dah
Maybe they should 'pad' the version numbers...
If I were numbering it it would have been 4.5.1.06...which makes 4.5.1.56 a rather obvious update,
It has always been done that way with DAZ Studio. It is numerical, not decimal, and 56 is bigger than 6. Once you know that, it is simple enough. To change it now might cause even more problems.
EDIT:
Thanks a lot!
