Collision in DS4.5
ZamuelNowZamuelNow Posts: 753
I've know of this but I've never known exactly where the option is. I know that you're limited to one collision per item and that Autofit is technically an example but I've never known anything past that.
  • edited December 1969
    Just off the top of my head, if the item already has a smoothing modifier put on it, then you'll find it under paramaters --> general--> mesh smoothing.
    If it doesn't have a modifier already on it, then select it in the scene tab and then (i think go to edit-->figure-->smoothing modifier. That may not be right. (or edit-->object-->smoothing modifier if you're working with an object, not a figure.) That should be enough to get you in the right area of the menu, if it's not quite right. (I'm away from my own computer right now.)
