Which Genesis UV Map?
DraagonStorm
Not sure if this is were I should be asking this...
Does any one know if there is any way using Python script in Poser to find out which UV map has been assigned to Genesis?
no, but if you want to change the texture and you are not sure you could always run the script to change it to what you wanted and then apply your texture I suppose.
What script to change the UV? I've been trying to figure out how to do that.
MEC4D UV Switcher Freebie will do that. But it not what I need.
My products do overlay textures to existing textures, so I need to know what UV Genesis is using.
