Viewcontrol disappears during changings
WolpiWolpi Posts: 323
I'm German and I can't find the adjustment option :red:to change the viewcontrol in the moment I'm dragging or turning the model. Since some days I can only see white marks and angles of the model then.
    You need to go to Window > Tabs > Tool Settings, and change the DrawStyle to 'Use Current (Off)'. It is probably set to Switch to Wireframe Box at the moment. See if that helps.
  • WolpiWolpi Posts: 323
    Thank you sooo much, dear Jimmy! Have a magic Xmas!!
    You are most welcome!
    And a Merry Christmas to you and yours.
