Is There a Particle system plugin for DAZ Studio?
Rareth
I done a search and can't seem to find anything, closest thing I've found is the Fantasy and Sci-Fi Effects which are basically props with neat materials. work great for some things, but its still no particle system.
Yes, the particle system is called 'export to Blender.'
j/k ofc... no, there is no particle system, nor a physics engine.
yah I was thinking I was going to have to resort to using Blender or Carrara generate particle effects..
There was a product called Particle FX for DAZ Studio; but I can't seem to find it in the store.
yeah that popped up on Google, but doesn't seem to exist.
I believe ParticleFX was similar to Jepe's Plates, i.e. the type of item you mentioned in first post. The closest thing I remember seeing to a particle system is Blowin in the Wind which is limited in what effects it produces. The fact there is this tool indicates that a plugin offering particle effects to some extent could be made for DS, but how extensive the functionality would be would take some research.
Edit: for ParticleFX, take a look here.
ok thanks for the info, well I guess I'll be using Carrarra's particle system to do what I need for now
