miachel versions explenation needed - noob alert!
ndrzejandrzeja Posts: 0
I'd just like to clarify if the additional models for the Michael model - internal organs and skeleton will work with the Michael v5 ? The product listed as compatible is just the Michael V4. Not sure if that's an outdated info, or is it really not compatible.
    edited December 2012
    Michael 4 is an older product compared to Michael 5
    Michael 4 is a standalone figure, Michael 5 is a variant of Genesis, and needs Genesis to work. Genesis is the default DAZ 3D figure which comes with Daz Studio 4+
    Hope that helps a bit
    The internal organs and skeleton were built to work with M4
    Post edited by Chohole on
  • ndrzejandrzeja Posts: 0
    That's the part I'm interested in. Does it mean it won't work with the V5 ?
    Thanks for the quick reply.
  • BlackFeather1973BlackFeather1973 Posts: 739
    You could auto-fit them to genesis, but i wouldn't expect a perfect result. There's a recent thread on the same subject here : http://www.daz3d.com/forums/discussion/13473/
  • MachieltjeMachieltje Posts: 0
    The easy answer: The M4 skeleton and M4 internal organs will NOT work with Michael 5.
    The advanced answer: The DAZ figures come in generations; Michael 5 is a fifth generation character while Michael 4 is a fourth generation. Now while a lot of stuff designed for M4 will work on M5 through the auto fit (provided you have the V4 and M4 shapes for Genesis installed) I'm not sure this would work on the skeleton and internal organs. You might get some kind of result through careful resizing but it would take time and effort and might not look all that great...
    edit: pff should type faster :P
    Post edited by Machieltje on
  • JaderailJaderail Posts: 0
    I hate to say it but I Second that answer. In my use of Genesis and the 5 Versions only clothing sort of works and Textures work if set to the M4 or V4 UV map.
    Thanks for all the answers. I guess I should have thought through my V5 purchase ...
