Its fully functional as in all parts that should move on the real gun do. Modeling is high quality and you get more then just the gun with it. Excellent price for the quality and options. His other weapons are of the same quality workmanship.
It says it's foir Poser. Does it work iun DS?
I was thinking more like a Gloick, but I might consider the Desert Eagle.
I actually made a list of available weapon packs a while back for an ongoing project (some names are descriptive rather than manufacturer's originals and this doesn't include a whole bunch I already own/picked up as freebies or that are buried in other packs such as uniforms):
Would really love to see Motokamishii make a Walther P99!! I love that pistol. It's up there in my most favorite's along with Desert Eagle and HK USP. Not sure if it would be appropriate to contact him with a request.
Rogue - Jet Li (War/Rogue Assassin)
Serene - Kate Beckinsale (Underworld)
007
These people made me love it. I also love the sleek design. And the handle is beautifully shaped.
Considering a gun is built purely for killing people, I have to say the P99 is particularly beautiful. Now that James Bond has gone back to his trusty Walther PPK for the latest brand of movies I have started to like that one too. I'm a bit of a fan of the new James Bond franchise. Hated it before!
It's amazing how something so deadly can be so beautiful lol
Tigers, leopards, Panthers, Lions... All beautiful and all very deadly! lol And let's not forget the innocent looking Panda's :-P
So, do you think it would be inappropriate of me to send Motokamishii a friendly request for a Walther p99? I've never contacted a vendor to make a request, and not sure if it's just an annoyance to them :S
007
Not that great, really. I own that exact model (with the Titanium slide.) It's not the most comfortable pistol to shoot, regardless of which backstrap is installed. (Though I think that still falls on the 1911, the Sig P-228 is a close second.)
Yes they do. What does NOT work by default is the ability to parent the bullets to any of the revolvers chambers inorder to have them rotate with the chamber.
Two ways around that are to have DS show hidden files and then find the chamber in the list and parent the bullets. The second method, wheich I prefer is to edit the CR2 files for the guns so that the parts are showing by default instead of being hidden.
I know from speaking briefly with Motokamishii that he does not use DS at all and works strictly in Poser. Plus he is Japanese and doesn't really know any english.
007
Oh great, I feel like a super noob again. How do I edit a CR2 file in this way? I only ever play with OBJs.
I will post the instructions later after I come back from the movies or some time tomorrow. Just dont know if my friends and I are doing anything after the movie or not.
Until then, I will highly suggest you use Notepad++ - http://notepad-plus-plus.org/ - for editing as you can open hundreds of files at once AND it automatically backups the file your editing too.
No need for all this Editing unless you NEED a bullet in the Chamber for every render. Do this instead.
Create a new Node position it at the center of the gun. Parent the NODE to the gun. Position the Bullet properly, now Parent the Bullet to the NODE. For later use Save as Scene or Scene Subset. No need to edit a single thing.
The bullets load in place but by default cannot be parented to the chamber and spin with it like it does in poser. So the null wont do anyone any good. I suggest editing since it saves you from having to expose the hidden nodes everytime to aceess what you need which includes applying a different surface shader.
In the screen caps below you will see what you are looking for in the CR2 and what it should look like when you are using Notetab++ to change it. Choose "Replace All in All open Documents" regardless of how many files you have open.
Make sure you click on the icon that looks like several disks inorder to save multiple files at once.
I'm not sure how Notepad++ does it but changing the file extension to .bak or adding a "~" to it are more or less universal methods of designating a file as a 'backup'. The original would be something like 'somegun.cr2.bak' or 'somegun.~' and edited file will then be saved as 'somegun.cr2'...done automatically by Notepad++.
Notepad++ is probably the best piece of Windows software around. (Said by a true Linux fan...)
Anyways, dont worry about the boxes. Just find one of the headings and you can highlight the "hidden 1" and then do Ctrl+H and have the search and replace option come up and you will see it filled in the field for you. I normally just copy and paste from the first field to the second field and replace the 1 wit a 0. And dont worry about making a mistake. If you do, you can just extract the original from the zip file. If you want two copies of the gun, simply rename the CR2 and corresponding PNG files, edit those CR2 files and then extract the originals from the zip file again and there you have 2 different copies.
Many thanks for the list, and for the how-to for fixing the .cr2 files of Motokamishii's excellent gun models to be D|S-friendly. I was stuck for a long time figuring out how to make these work properly in D|S, and more importantly, able to fix the materials so I can add the proper metal sheen and bump maps. Incidentally, has anyone made proper D|S materials presets for these guns? I'm getting somewhere now, but it's very slow going.
It looks like a Desert Eagle Mark XIX, most likely in .50AE calber.
That was a freebie at DAZ in the past. It is no longer available.
If you need a Desert Eagle, I HIGHLY recommend this one - http://www.renderosity.com/mod/bcs/ide50-for-poser/73009
Oh nice!
There are some awesome guns at Rendo that are easy to miss because of the search system. Thanks for the link!
Your Welcome! Motokamishii's guns are excellent.
S&W Model 29 4" http://www.renderosity.com/mod/bcs/swm29/55505
S&W Model 29 6.5"
S&W Model 29 8.75"
S&W Model 629 4"
S&W Model 629 6.5"
S&W Model 629 8.75"
Automag .44 6.5" Early http://www.renderosity.com/mod/bcs/amg44-/56677
Automag .44 6.5" Late
Automag .44 8.5"
Beretta M92 4" Steel http://www.renderosity.com/mod/bcs/brm92/59048
Beretta M92 4" Blued
Beretta M92 5" Steel
Beretta M92 5" Blued
Beretta M96 4" Steel
Beretta M96 4" Blued
Beretta M96 5" Steel
Beretta M96 5" Blued
Glock Model 38 .45 GAP http://www.renderosity.com/mod/bcs/agm19/64676
Glock Model 19 9mm
Glock Model 23 .40 S&W
Derringer Blued http://www.renderosity.com/mod/bcs/rdd41/70814
Derringer Chromed
Derringer Gold
S&W Model 500 4" .500 S&W http://www.renderosity.com/mod/bcs/swx500/71581
S&W Model 500 4" .500 S&W (Two barrel variants)
S&W Model 500 8.75" .500 S&W
MRI Desert Eagle 6" .44 Magnum http://www.renderosity.com/mod/bcs/ide50-for-poser/73009
MRI Desert Eagle 10" .44 Magnum
MRI Desert Eagle 14" .44 Magnum
MRI Desert Eagle 6" .50 AE
MRI Desert Eagle 10" .50 AE
Colt .45 Single Action 4.75" Nickel http://www.renderosity.com/mod/bcs/csa45-for-poser/74054
Colt .45 Single Action 5.5" Nickel
Colt .45 Single Action 7.5" Nickel
Colt .45 Single Action 12" Nickel
Colt .45 Single Action 4.75" Blued
Colt .45 Single Action 5.5" Blued
Colt .45 Single Action 7.5" Blued
Colt .45 Single Action 12" Blued
Beretta 92 Belt Holster Right Yes http://www.renderosity.com/mod/bcs/hipholster-pack-for-brm92/74413
Beretta 92 Back Holster Right
Magazine Pouch Left
Beretta 92 Belt Holster Left
Beretta 92 Back Holster Left
Magazine Pouch Right
Beretta 96 Belt Holster Right
Beretta 96 Back Holster Right
Beretta 96 Belt Holster Left
Beretta 96 Back Holster Left
IMI Jericho 941 9mm http://www.renderosity.com/mod/bcs/ijr941-for-poser/76389
IMI Jericho 941 .41 AE
IMI Jericho 941 .40
IMI Jericho 941 9mm (2nd Variant)
IMI Jericho 941 .40 (2nd Variant)
IMI Jericho 941 Composite 9mm
IMI Jericho 941 Composite Short 9mm
IMI Jericho 941 Composite Compact 9mm
IMI Jericho 941 Chromed 9mm
IMI Jericho 941 Chromed Short 9mm
IMI Jericho 941 Chromed Compact 9mm
IMI Jericho 941 Composite .40 S&W
IMI Jericho 941 Composite Short .40 S&W
IMI Jericho 941 Composite Compact .40 S&W
IMI Jericho 941 Chromed .40 S&W
IMI Jericho 941 Chromed Short .40 S&W
IMI Jericho 941 Chromed Compact .40 S&W
IMI Jericho 941 Composite Short .45 ACP
IMI Jericho 941 Chromed Short .45 ACP
Browning Hi-Power http://www.renderosity.com/mod/bcs/bhp9-pack-a-for-poser/77141
Browning Hi-Power Mki III
Browning Hi-Power Commercial
Browning Hi-Power Capitan http://www.renderosity.com/mod/bcs/bhp9-pack-b-for-poser/80322
Browning Hi-Power Military
Browning Hi-Power Practical
Browning Hi-Power Wooden Stock
Winchester Model 1873 30" http://www.renderosity.com/mod/bcs/wrm1873-for-poser/81498
Winchester Model 1873 24" All with Blued, Nickel or Case-Hardened Finishes
Winchester Model 1873 16"
Winchester Model 1873 Sawn-Off
Winchester Model 1873 Octagonal Barrel 30"
Winchester Model 1873 Octagonal Barrel 24"
Winchester Model 1873 Octagonal Barrel 16"
Winchester Model 1873 Octagonal Barrel Sawn-Off
Colt M1911A1 Series 70 http://www.renderosity.com/mod/bcs/cgv45-01-for-poser/83259
Colt M1911A1M
Colt M1911A1ME
Colt M1911A1ML
Colt M1991A1M http://www.renderosity.com/mod/bcs/cgv45-02-for-poser/83909
Colt M1911A1 Series 80 SN
Colt M1911A1 Series 80 SE
Colt M1911A1 Series 70S
Colt M1911A1 Compact LW http://www.renderosity.com/mod/bcs/cgv45-03-for-poser/84453
Colt M1911A1 Compact 70S
Colt M1911A1 Compact 80SE
Colt M1911A1 Compact 80SN
Colt M1991A1M Compact
Ingram M10 .45 Early http://www.renderosity.com/mod/bcs/ingm10-for-poser/85443
Ingram M10 .45 Later
Ingram M10 9mm http://www.renderosity.com/mod/bcs/ingm11-for-poser/86217
Ingram M11 9mm
Ingram M11 Ext (8 Variants) http://www.renderosity.com/mod/bcs/ingm11ext-for-poser/87538
Colt M1911A1 Compact 80SE http://www.renderosity.com/mod/bcs/cgv45-04-for-poser/88453
Colt M1911A1 Compact 80SLW
Colt M1911A1 Compact 90SLW
Colt M1911A1 Compact DTNX E
Colt M1911A1 Compact DTNX L
S&W Model 29C 5" http://www.renderosity.com/mod/bcs/swm29c/56250
S&W Model 29C 6.5"
S&W Model 29C 8.75"
S&W Model 629 5"
S&W Model 629 6.5"
S&W Model 629 8.75"
Holster, Right, for S&W Model 29C 4"
Holster, Right, for S&W Model 29C 5"
Holster, Right, for S&W Model 29C 6.5"
Holster, Right, for S&W Model 29C 8.75"
Holster, Right Rear, for S&W Model 29C
Holster, Left, for S&W Model 29C 4"
Holster, Left, for S&W Model 29C 5"
Holster, Left, for S&W Model 29C 6.5"
Holster, Left, for S&W Model 29C 8.75"
Holster, Left Rear, for S&W Model 29C
Para-Ordnance M1911A1 Long Slide Early http://www.renderosity.com/mod/bcs/cgv45-05-for-poser/89894
Para-Ordnance M1911A1 Long Slide Late
Para-Ordnance M1911A1 Long Slide Scope Mount
Para-Ordnance M1911A1 High Capacity http://www.renderosity.com/mod/bcs/cgv45-06-for-poser/93497
Para-Ordnance M1911A1 High Capacity Compact
Para-Ordnance M1911A1 High Capacity Sub Compact
Para-Ordnance M1911A1 Sub Compact Variant http://www.renderosity.com/mod/bcs/cgv45-07-for-poser/94070
Para-Ordnance M1911A1 Blued with Accessory Rail
Para-Ordnance M1911A1 Stainless
Para-Ordnance M1911A1 Stainless Variant
Remington Model 70 http://www.renderosity.com/mod/bcs/rem-model-700---rifle/87852
Shooting Range http://www.renderosity.com/mod/bcs/shooting-range-for-poser/85211
Goggles
Ear Protection
Generic Compact 9mm
M240G http://www.renderosity.com/mod/bcs/dirtyeddys-m240g-machinegun/73960
M1911A1 http://www.renderosity.com/mod/bcs/colt-45-1911/62824
Assault Weapons Pack 2 http://www.renderosity.com/mod/bcs/assault-weapons-2/62506
FN FAL
HK G3
Uzi
Simonov SKS
L2A3 Sterling
M14
M16
HK XM8
Assault Weapons Pack 1 http://www.ontarget3d.com/site/Products/91-assault-weapons-1-for-poser.aspx
CETME LC
FAMAS F1
FR-F1
Galil SAR
HK33
L85A1
MAT49
SG540
Assault Weapons Pack 3 http://www.renderosity.com/mod/bcs/assault-weapons-3/61435
AKS-74U
Colt Commando
Dragunov SVD
HK G36
Lusa A2
Negev Commando
QBZ-95
Spectre M4
Assault Weapons Pack 4 http://www.renderosity.com/mod/bcs/assault-weapons-4/61436
AGM1
Steyr AUG 9mm
Beretta 70/90
FN P90
HK MP5
L1A1 SLR
Stoner M63
IMI Tavor TAR21
Weapons Pack Axis Forces http://www.renderosity.com/mod/bcs/wwii-weapons--pack-2-axis-forces/44346
Kar 98k
FG42
MP40
MP44
Luger P08
Luger P08 Navy
Walther P38
Mannlicher Carcano Model 38 Rifle
Mannlicher Carcano Model 91 Carbine
Beretta Modello 38/42 SMG
Beretta Modello 1934 Pistol
Arisaka 99th Year Rifle
Meiji 38th Year Carbine
Type 100/44 SMG
Taisho 14 pistol
Mauser C96 (Broom-Handled Mauser) http://www.renderosity.com/mod/bcs/1930s-style-autopistol/28531
Classic Handguns - 2 http://www.ontarget3d.com/site/Products/992-classic-handguns-2-for-poser.aspx
Astra 400
Colt New Service
Browning High Power
S&W 28/200
Classic Handguns - 1 http://www.ontarget3d.com/site/Products/462-classic-handguns-1-for-poser.aspx
Enfield No2 Mk I
Mauser M1912 (Broomhandle)
Nagant Model 1895
Tula Tokarev TT33
Urban Assault Weapons http://www.ontarget3d.com/site/Products/358-urban-assault-weapons-for-poser.aspx
HK USP-45
Ingram MAC-10
TEC-9
UTC-Shotgun
Winchester 300 Magnum http://www.renderosity.com/mod/bcs/index.php?ViewProduct=76904
Barrett M82A1 http://www.renderosity.com/mod/bcs/index.php?ViewProduct=76876
HK MSG90 http://www.renderosity.com/mod/bcs/index.php?ViewProduct=77015
WW2 Guns USA http://www.renderosity.com/mod/bcs/index.php?ViewProduct=66502
M1918A2 BAR
M1 Garand
M1903A1 Springfield
M1 Carbine
M1A1 Carbine
M1A1 Thompson
M3A1 Grease Gun
Colt M1911A1
Mk 2 Grenade
HK416 Modular Assault Rifle http://www.renderosity.com/mod/bcs/hk416-modular-assault-rifle/76567
Morphing UMP 45 http://www.renderosity.com/mod/bcs/morphing-ump45-machine-pistol/77492
Remington Model 870MCS Stockless Pump Action http://www.daz3d.com/shop/the-firearm-pack
Daly ZDA 9mm Pistol
DSA SA58 FAL Para Elite
Walther G.22 Bullpup .22
S&W Model 649 Chief's Special .357 Magnum
S&W Model 686
M1928 Thompson SMG
DPMS AR15 Pistol
Oh, crap! That's one heck of a list!! And there is a Glock listed. Thanbs!
O.o *faved* Thanks!
007
Consider a tiger....
..Joe
*Bookmarked thread for list*
Me too!! ;-)
I would still like to learn how to edit the .cr2. Who knows? Maybe it will become my preference.
It's THAT easy? Well, I'm still nervous that I might bust something, like...my computer screen or my head!
Installing Notepad++ now.
If I wanted to save a copy of the original .cr2, how do I get the new one to load instead of the original?
Okay, I have all five gun .cr2 files loaded up on Notepad++. The right ones, right?
How the heck do I type those Wingdingy-looking boxes? If it requires a numpad, I don't have one.
I ran a search through one of those monstrous cr2s. Couldn't find the hammer_pin. I think i opened the wrong cr2s.
What gun are you editing? The IDF50?
panko's guns are the best because they come with matching poses. I can't pose for nuts.
And of course they "work"
Love esther
http://www.renderosity.com/mod/bcs/index.php?vendor=panko
