Genesis skin shader help
nickalamannickalaman Posts: 196
Hi,
Wondering if there is a script or a way I can apply a value for glossiness and shininess to a figure after I've applied my skin mat. I can of corse apply each node manually but that takes too much time, espcially if i change my mind and would like to try different values.
Working with 8.5 pro.
Thanks,
Nick
  • Akulla3DAkulla3D Posts: 131
    edited November 2012
    Hi,
    Thanks,
    Nick
    There is no script as far as I know. One good way to do it is to select Consolidate Duplicate Shaders, once you do this then there are only 4 shader domains (V4). This is a little less time consuming, I do this all the time and it adds only about 5 minutes to my process.
    Post edited by Akulla3D on
  • nickalamannickalaman Posts: 196
    Thanks,
    Didn't know about the consilidate.
  • SzarkSzark Posts: 10,634
    akulla3D said:
    [ One good way to do it is to select Consolidate Duplicate Shaders, once you do this then there are only 4 shader domains (V4). This is a little less time consuming, I do this all the time and it adds only about 5 minutes to my process.
    I have tried to find this function in DS4.5.1.6 and for the life of me cannot find it. Can you please let me know where I can find this.
  • CarltonMartinCarltonMartin Posts: 147
    This is the Carrara forum, and "consolidate shaders" is a Carrara function.
    Now don't I look an idiot which is no change...sorry about that. That's what you get for not being able to sleep for 48 hours and counting. I use Carrara and didn't know it exisited so at least it will help me. :)
