Question about the Daz FBX Exporter
Hi all,
I've made a figure in Daz Studio 4, originating from M4, and I've used morphs to make him very skinny.
Now, I try and bake those morphs when I export as a FBX out of Daz, but when I import it into other software, the Michael figure isn't skinny anymore.
In other words, the morphs haven't carried over with the FBX format. Can someone please let me know if this is a bug, or am I doing it wrong? I tried to smooth the morphs, but that just crashed Daz.
Secondly, if you know of a tutorial clip about the FBX Exporter plug-in, I'd really appreciate it if you could post the link.
Many hanks in advance :)
Paul
  • bighbigh Posts: 8,147
    Carder123 said:
    Hi all,
    Paul
    the last info I saw - they are still working on it
    did you try obj format ?
  • edited December 1969
    Hi Bigh, no I didn't opt for OBJ because I'm having to keep the clothing editable and am taking it into iclone's 3DXchange.
    They have this tuorial - http://www.youtube.com/watch?v=2Y63R_VEXF4&feature=player_embedded
    ...and it appears to work. Not for me it doesn't.
    got you - I have done one for iClone - worked fine for me
    will try another - get back to you
    Are you using a Genesis character or a Michael 4 base character? All my characters are M4 and V4 - which I'm guessing doesn't export properly as an FBX file.
    If you've successfully exported a M4 character as an FBX, could upi possibly share the export settings with me? and do you have to smooth the morphs and reduce the polygon count before exporting?
    I did Genesis - didn't try M4 .
    I just did it as is - no smooth or reduce polygon count .
    you should reduce polygon count - I was doing a test to see how it would work .
    just tryed baby3 - worked fine - big polygon count 132,000 - so M4 should work
    I don't suppose you could try it out on a Michael 4 figure your end?
    I don't want to give up on M4 just yet, as I've spent a lot of money on Morphs ++ and M4 clothing.
    sure if I can fine M4 .
    I just bought the Genesis Evolution Morph Bundle from the store: http://www.daz3d.com/shop/genesis-evolution-morph-bundle
    Have a feeling I'm going to have to design my characters from scratch using Genesis.
    I keep trying FBX exports of M4....doesn't work :(
    have you tryed V4 - just to see if it works - if it does work for you then M4 should
    will get back to you later - got to get some zzzzzzzzzzz
  • Daily_DoodlerDaily_Doodler Posts: 34
    thats a very long sleep bigh! I'm having Studio FBX export - Maya troubles myself. Animation associated with clothing doesn't appear in Maya. gav (sweet dreams)
    just waking up ;-)
    don't have Maya so can't tell you what to try - sorry
    wow...this was a while ago! Don't worry chaps...thanks to the following releases, I worked around this problem;
    I found a way of sticking with my M4 and V4 shapes with THIS
    ...and so my Daz Pro 4.5 Autofit fits all my M4/V4 clothing to Genesis!
    Oh, and THIS was the best $20 I've ever spent!
    As Iclone only really accepts Genesis at the moment (or so I'm led to believe).....this is problem solved! :)
    Yeah they're really good add ons! dont suppose you had any joy exporting animated dynamic clothes
    the only program that I know it will work in is Carrara 8.5 pro .
    Hi gcookman, I agree with Bigh. I tried to play around with dynamic clothes exporting once, but it's impossible to get your Daz dynamic clothing working in anything other than Carrara. (Maybe if you're advanced super-brain it might be, but for the average hobbist consumer like myself, it's not)
    As Daz is SO hopeless at attaching 'sef-made/non-AniMate' BVH's to it's characters, I'm simply exporting out the models, and then using iClone's 3DXchange Pipeline to attach them instead. Then tweaking the poke-throughs and hand gestures in Motionbuilder.
    Daz really needs to address it's timeline functionality. If I want my character to belly-dance or perform martial arts..I'm laughing!, but if you assign BVH's (in my case, made in Ipi Soft)......you get roadkill.
    Sort it out in version 5 please Daz! :) Wake up.
    Thanks for the above Bigh, that's a bummer.
    Hi all (again)....listen, I know I'm a novice at Daz...hands up, I admit it!
    If you make a fat guy dance in Daz, his belly bounces! right?
    ....is there a way (via a third-party plug-in perhaps) to export those weight maps (or ...ahem....whatever they're called) into Motionbuilder?
    Would love to know th answer to THAT one! :)
    Hey Carder,
    I've managed to export the dynamic clothes animation by using the "freeze animation" function in the Dynamic plug in add on. When the dynamic bit loses touch with the main figure once in Maya. Hopefully I get that sussed sooner rather than later!!!!
    Now I've always found attaching BVH pretty good in Daz, what's the issue you have? The poke through thang! have you tried the Apply smoothing modifier? You have to be on the scene tab, select the item of clothing, then that little dropdown at the top left edit>geometry>apply smoothing modifier (4.5.1.6 version should be there in previous versions) should save you a bit of time it's fairly swift.
    Will keep an eye out for the weight maps problem not my bag I'm afraid. But surely if he's a fat guy he'll be carry the weight anyway!!!!!
