Joining the symmetry clones
ghastlycomicghastlycomic Posts: 2,370
edited December 1969 in Hexagon Discussion
So I tried building a figure today using symmetry to build one half then cloning it, but once I've cloned the figure how do I get the two halves to join together at the seams?
    Select them both in the Scene pane, and use the Weld tool.
  • ghastlycomicghastlycomic Posts: 2,370
    But it doesn't actually seem to join them along the seams. It makes them one object but I find when my figure is posing or moving there are places where it looks like he's split his pants at the seams.
  • GhostmanGhostman Posts: 215
    Select the edges on both halves then hit the L key to make a loop. Then go up to the menu and click Selection / Convert selection to points. Then use the average weld tool to connect the halves.
  • edited October 2012
    Only 2 caveats to expand on here:
    1: The 2 halves must be welded into a single object first.
    2: Be VERY CAREFUL with the "distance" adjustment. If adjacent points on either half are closer then the seams are to each other, you risk welding 4 or more points in places you only intended to weld 2.
    One slick way way of minimizing or avoiding #2 is to add one step before average welding the points:
    I made a sphere, cut it in half, and then mirrored it. Then I deliberately snaggled various points to exaggeratedly mimic problems commonly encountered while modeling half sections.
    Then I selected the edges as per Ghostman's method. Note the yellow arrow pointing at the "X size" parameter. This non-zero value indicates a deviation of some edge positions from a common vertical axis.
    Set that value to zero and hit enter, and you get all the edges snapping perfectly aligned and vertical. (some details here that are usually no major problem but that you MIGHT want to check on with some models are that this method only assures vertical axis alignment. It does NOT assure that this vertical alignment is perfectly centered between the 2 halves (although it usually is), and it does NOT assure that point pairs are matched HORIZONTALLY)
    From here you can convert edges to points and then average weld them.
    679 x 637 - 111K
    679 x 637 - 278K
    679 x 637 - 113K
    Post edited by emfederin_9bc0c524c8 on
    Thanks gang, that did the trick!!
  • RoygeeRoygee Posts: 2,220
    A quick way to check that all verts are welded is to hit the "Fill" button after doing the average weld. If a white line appears, it has not worked. Don't fill - abort then go back and finish the job.
  • BryonSpellerBryonSpeller Posts: 0
    You could SHIFT select both items and do what you do here without welding the halves into one object first.
