Question... when you apply something like lie wound... Where are the layers visible?
Serene Night
Hi:
I was wondering how to find when you apply a lie wound... Or one of the grunge shaders... I was told I could adjust the transparency of the layer and make it less sharp... For example: making a bruise less harsh...
does anyone know where I could find info on doing this?
Thank you.
Surfaces Tab for the Material Zone you applied the Shader to.
On the Surface Tab click on the Diffuse Strength arrow and select Layered Image Editor to get the LIE interface. Then you will see the Opacity slider. You will be prompted to save after you are done with your changes. Give it a unique name, it won't change your original layer. Now when you reopen your scene your layers will load with your edited settings.
Thank you SimonWM. this was very helpful and the screenshot illustrated it perfectly.
Thanks ya'll for your help. I now understand what folks are talking about when they say to click on the little arrow. I was having trouble finding that.
GRAS,
Serene.
