Auto-fit Shoes on Genesis (tips)
cm152335cm152335 Posts: 421
edited September 2012 in Daz Studio Discussion
Hi all.
could be that help,,
i found a possible way to fix the wrong auto-fit feature for shoes,,
i thing is no need to wrote,, just check the image...
http://home.scarlet.be/magic_touch/genesis_autofit_shoes.jpg
i put the shoes in the scene, (not on the character) i apply changes and
after fit to > Genesis, i don't do anything more than get screen!
most of shoes work great,, need to find if that work with all type of shoes.
1920 x 1038 - 411K
Post edited by cm152335 on
  • cm152335cm152335 Posts: 421
    next try with boots
    i use the same way as more up
    http://home.scarlet.be/magic_touch/genesis_autofit_shoes2.jpg
    Additional info’s:
    The character is Genesis> Victoria 5 - supermodel>
    The shoes and boots is old standard V4
    Note all shoes work so easily, but most of them, Yes.
    1852 x 976 - 212K
  • Jim_1831252Jim_1831252 Posts: 728
    Will have to give this a go. Been working on a different approach, especially for heals, but if this works then all my work has been a horrible waste of time lol
  • cridgitcridgit Posts: 1,757
    edited May 2022
    Redacted
    Post edited by cridgit on
    it seems quick way, but it is aslmost same when you just parented the shoe to genesis.
    if you feel "not auto fit" is better, it means "auto-fit" has no means about adjust shape of heel boots or shoes .
    as for me, I use auto-fitted triaxed figure for just donner rig and morph .
    after all, you must need adjust shape by modeler, (I ofthen delete half of them and,
    after reshape copy ,then grouped one shoes)
    and It may need for best pose preset to wear shoes.
    if now you get shoes which can fit -to genesis shape,]
    but you may need if you change the genesis shape with many morphs,
    you must make morph and overwrite morphs for each shape too.
    about shoes , auto-generated morph efefct is far from perfect.
    770 x 496 - 60K
    788 x 498 - 63K
