Power loader V4 does not select the correct skin preset in 4.5
HeraHera Posts: 1,952
Hi!
Since installed DAZ 4.5 the V4 powerloader refuses to select the correct skin preset for V4. I've selected All Natural, but it still loads Bikini. Now how do I fix this?? (Except for renaming the skins of course which sounds like a 'dirty solution')
    edited August 2012
    It doesn't work for me either, but I never knew it existed before today.
    I think it must be a bug in the Powerloader.
    EDIT:
    I just tried this in 4.0.3.36 32 bit version, and it works fine, must be a bug in 4.5.0.114
    Post edited by JimmyC_2009 on
    It may be worht while submitting a bug report for this please Jimmy. RH agrees.
    I am getting right on it now!
    Thank's Jimmy
    I have made a bug report on this, https://bugs.daz3d.com/view.php?id=47690
    I also reported the fact that the render settings are not retained when set to Active Viewport. The next time DS4P loads, they are set to Custom, and a weird size, 569 : 353.
    https://bugs.daz3d.com/view.php?id=47691
  • ZwytZwyt Posts: 119
    Another thing that I am noticing in the V4.2 Power Loader is that its not loading any morphs beyond the base morphs and Aiko 4 and maybe Legacy Injection Slots. The rest of them are checked but say "No Metadata Found" with a product number out beside the message in parentheses as follows:
    No Metadata Found (ps_mr258)
    No Metadata Found (ps_mr259)
    No Metadata Found (ps_pe070_DAZ)
    No Metadata Found (ps_pe072_DAZ)
    Also if I assign a preset to load with V4.2 as the previous poster mentioned the preset does not load, she still loads with that little painted on purple bikini. Oh and I am using 4.5 Pro as well.
    Thanks in advance,
    Charles
    edited August 2012
    I get the Metadata error for mr258, International Faces for V4. I am going to reset my download to get the latest version, reinstall, and see if that cures it. The loading with the basic skin with purple bikini has been reported, and will hopefully fixed.
    I will let you know how I get on with International Faces, and maybe that will cure your faults as well.
    EDIT:
    I donlt hink it is International Faces that is causing the problem, but the one below it. I don't know what mr258 is now, so I can't reset it?
    Why did DAZ have to change all the stupid numbers :)
    OK, ps_mr258 is the Creature Creator morphs for V4, and you need to reinstall the latest Powerloader file for it.
    The one I used was ps_ac2016_CreatureMsPwrLoader.exe, and I no longer get the Metadata error message. The same method should fix the rest for you.
  • SkirikiSkiriki Posts: 4,975
    Powerloader for Millennium Subdragon is also acting pretty hosed on my system.
