SR3 is ready
wimvdb_dc63ee9ce6wimvdb_dc63ee9ce6 Posts: 183
edited December 1969 in Poser Discussion
See http://poser.smithmicro.com/updates.html
This includes a fix which eliminates the need for some of Cliff's cloth fitting scripts when using genesis in Poser
  • Cliff BowmanCliff Bowman Posts: 1,677
    It absolutely does a better job than at least 4 of my scripts, IMHO. Get SR3 - now :)
    Cheers,
    Cliff
  • wimvdb_dc63ee9ce6wimvdb_dc63ee9ce6 Posts: 183
    For those who are using scaled figures in Poser:
    There is a new property in the body actor: Follow Origins when Conforming. This is what makes the magic of the animated joints happen in SR3
    edited August 2012
    And by animated, he means animated... my "M4 to Genesis Gorilla" animation can now wear clothes throughout the animation :D
    Post edited by Cliff Bowman on
  • WandWWandW Posts: 2,785
    Sweet! :coolsmile:
    It's going to be a long week until I can try it...
  • KerwinKerwin Posts: 124
    Just gave the new GoZ plugin a quick work out. It definitely makes creating new morphs a snap! (Although Colorcurvature's scripts also eliminated most difficulties in making Poser FBMs.) Appears to work for both posed and un-posed figures.
    -K
  • namretteknamrettek Posts: 168
    How does the Goz work? I just installed sr3 and didn't see any goz button. Nor can I find any explanation of how it works.
    Under file export I found a zbrush option but that only saves a file... or is that the goz function? (other goz butttons open up zbrush and give me a tool...
    I guess what I am trying to figure out is - Is the exporter just a save function?
    because when I try to goz from zbrush it only goes to Carrara...
    It is in the Figure and Object menu: Figure! Export to GoZ and Object!Export Object to GoZ
    A figure or a prop needs to be selected before the menu becomes active
    Thanks!!
    Not sure how I missed that. If it was a snake... I think I was stuck on looking for Goz (at the beginning of the command...)
    Wow instant morphs!!
    My wacom tablet still doesn't seem to work very well with Poser - does anyone use a tablet to control the Poser interface or is that mostly just for painting and morphing?
    I find it hard to use the tablet for any UI manipulation (not in Poser or any other app). I always use the mouse until I have to paint, then I switch to the tablet..
    But I have used a mouse since the early 80s, so I am pretty used to it
  • IvyIvy Posts: 7,153
    edited August 2012
    I'm glad the fixed the color picker trouble i was having .. now my color pallet is working much better, i can actual get the colors i picked instead of picking a color and it be off from what it looked like in the pallet.
    Post edited by Ivy on
  • edited December 1969
    What are the issues that you're seeing with the tablet?
  • DoricDoric Posts: 80
    No problems installing or downloading, several instabilities gone, definite improvement in the morph brush. Now to go further to see what else has improved, a great update.
    D.
    edited August 2012
    Single axis scaling is great; here's Lyrra'a Shape of a Woman 5 Foot pose applied to V4WM in SR3. No breaks in the arm and thigh! :coolsmile:
    368 x 600 - 11K
    Post edited by WandW on
