8.5 beta
Will this update my Carrara 8.1 to 8.5 or will it install a completely new separate application
  • frank0314frank0314 Posts: 13,383
    It says in the first paragraph of the announcement that it can run side by side to 8.1
  • edited December 1969
    Which mean I have to find updated versions of all my Plugins then such as DCG!
  • WendyLuvsCatzWendyLuvsCatz Posts: 37,815
    create a new folder and install it to that
    call it Carrara beta
    you can reinstall copies of your plugins to that folder too
    you manually create a shortcut to the program or your C8.1 dep on which one the desktop shortcut goes to
    I actually replaced C8.1 64bit but reinstalled C8.1 64bit to my external drive if I really need it, I have C8.1 32bit and C8.5 beta 64bit on my computer.
    stuff done in the 32bit renders in the 64 so if I do not want to use the beta, I just do it in the 32bit save and then render in tge 64bit beta.
  • jrm21jrm21 Posts: 140
    VERY important to do that. A default install of the beta will over-write the version 8 install. You must manually choose a different folder.
  • MiloMilo Posts: 511
    Should I uninstall the last Beta (I assume it won't touch the regular) or just install over it. I don't want extra uninstallers hanging around either.
