Make UI text bigger
HorizonHorizon Posts: 17
edited February 2020 in Daz Studio Discussion
Hello,
Do you know how to make text bigger and bold for the menu bar ?
Unfortunately, changing Window Style do not affect the menu bar, so I have bigger and bold text for the rest of the app if I am choosing Main Street, but not for the menu bar.
413 x 26 - 6K
Post edited by Horizon on
  • cm152335cm152335 Posts: 421
    try this,
    create a specific "new user" profile in windows to run only Daz studio
    on your desktop right clcik and go to "display parameters" and use the "scaling parameters" (100% - to - 500%)
    - try for test and see "150%"
    when you run daz studio it need to ajust your windows tabs
    note;
    the reason why i suggest you to use new user profile
    if you don't create a new user profile all applications should be use the same effect,
    in that case you don't need to reset for other app when you don't use Daz studio
  • FirePro9FirePro9 Posts: 455
    Might also play with Compatibility options. Right click DS icon, Properties | Compatibility Tab.
    1671 x 1085 - 210K
    Post edited by FirePro9 on
  • I'm having the same problem with small UI text size.  I have a 4k monitor running Windows 7.  I have the display scaling in windows raised to 177% so I can read the text in most apps, but Daz still has default text size.  Is there anyway to adjust this property?
