null object
laverdet_943f1f7da1laverdet_943f1f7da1 Posts: 252
Hi!!! in C8pro, where has gone the null object, that sort of no visible object to "point at"??? I can't find it! thank you for help!!!
  • evilproducerevilproducer Posts: 9,040
    edited February 2014
    Hi. Carrara calls them a Target Helper Object in English. I'm not sure how it translates to other languages.
    There is a target icon (circle with concentric rings) that is for the Target Helper Object. Simply drag it to your scene. You can also use the Insert Menu. I've included screen shots to illustrate.
    I use Carrara 7.2 Pro, so it is possible, though not very likely that they have moved or changed the icon in Carrara 8 and later.
    232 x 788 - 65K
    108 x 58 - 5K
    It will look like this, and you can change the size and color using the Target Helper Object's Effects tab.
    255 x 785 - 30K
    559 x 486 - 27K
