3D easy pose/morph splash objects - update
cosmo71cosmo71 Posts: 3,609
edited June 2012 in Product Suggestions
Hello, some different 3D splash objects with morphs would be great. At turbosquid you can find some 3D splash objects but they are static (except scale/rotation/position). such 3D splashes would be great to have with morphs.
here are links so you can see what I mean:
http://www.turbosquid.com/3d-models/maya-paint-splash-liquid/571866
http://www.turbosquid.com/3d-models/3d-model-splash-paint/571860
http://www.turbosquid.com/Search/Index.cfm?keyword=splash&x=18&y=15
morph suggestions:
-front wider
-front longer
-front drops longer
-front drops wider
-front move left/right/up/down
-front twist
-back wider
-back longer
-back drops longer
-back drops wider
-back move left/right/up/down
-back twist
with these morphs it should be possible to create real 3D splashes that indicates motion. that would be great for example water, drinks and blood (fighting scenes)
that is also great for renders with raytraced shadow because you have real 3d slpash shadow and with the right opacity values you will get great results
I think textures (jpegs) are not necessary, to have the possibillity to colorize these objects (diffuse/specular/ambient) and to fix the opacity, glossiness and reflection will be enough
maybe two or three different shader-groups so it is possible for the user to hide drops via opacity
Post edited by cosmo71 on
  • creativemodelsbecreativemodelsbe Posts: 0
    why morph's? why no particle system or better fluid inputs from realflow?
    animate fluids with morphs is to time taken proces.
  • cosmo71cosmo71 Posts: 3,609
    basically it does not matter to me how these splashes work, if there is another solution than it is okay, but these splashes should work in daz studio 3 and 4
    Should work in daz studio 3 because I am still a daz studio 3 user, I prefer daz studio 3
  • WendyLuvsCatzWendyLuvsCatz Posts: 37,808
    Casual did metaballs for DS3
    I have not tried them.
    where can I get some more informations about that? haven`t found it here at the store
