Adding faces
edited April 2017 in Hexagon Discussion
Hello!
I'm trying to follow this tutorial: https://www.3dtotal.com/ffa/tutorials/max/joanofarc/hair1.php
But I'm already stuck add the very first steps: Adding a face.
The instructions are: "Initially, you can guide yourself by working from the drawing of the head of face. Create a rectangular face on top starting from Shape Rectangle, then add Mesh Eddit or you can collapse the stack into an Editable Mesh."
So I select "Facet", then I click somewhere on the head of Genesis 2 Female, and I release the mouse button somewhere else, hoping it would create a new face.
However, this doesn't work, it seems to be gone although it shows up in the "Properties" pane on the right side.
I have recorded a video here that shows my attempt:
Could anybody lend a helping hand?
Thank you very much!
Post edited by johann.hesters_2e9dd0ece9 on
  • Try making the face away from the character., also when you've made the face (four points) press Enter twice, or apply and validate.
    The way I normally start this type of thing is with a cube, then select a face - Press the letter "I" to invert the selection and Delete, which will give you a simple face.
  • FistyFisty Posts: 3,416
    or just make a cube and delete 5 of the sides.
  • Wee Dangerous JohnWee Dangerous John Posts: 1,605
    edited April 2017
    cheeky
    Nice to see you here Fisty - How are things
    Post edited by Wee Dangerous John on
    Been better, but still alive and kicking..  How're you?
