faster render time in daz
SolarieSolarie Posts: 34
Hay gang can any one help me out here, i have gotten the latest M5 and V5 but the trouble with them is that the render time is terrible it takes over 8 min on one pass.
but with V4 and M4 it was like 1 min at max what can i do to get the render time down.?
  • fixmypcmikefixmypcmike Posts: 19,565
    I can't think of any reason the 5th Gen figures should take longer to render than the 4th Gen, all else being the same. What skin textures, clothing, and hair are you using?
  • SolarieSolarie Posts: 34
    The standard that it comes with and one other don't remember the name of it but it is the same for bout it takes ages. i also cant figure out what takes so lone if it is the reflection or the sss?
    As a test, you could try applying the same texture, hair, and clothing you're using on V4 to V5 and see if it still takes much longer.
    edited December 2012
    yes i can do that will post the result asap. to supliment to the problem am posting my computer specs
    i have and amd i7 920
    Radeon 5870 graphic card
    12 gb ram
    Post edited by Solarie on
    well that turned out on 1 min 13 sec that went faster.
    What version of DS are you running?
    4.0 pro
    i found out that it was it is the sss i turned it off and it went down from almost 10 min to somewhat over 1 min :)
    Solarie said:
    4.0 pro
    Not sure if you can get it lower with SSS off...but 4.5 has tremendous render speed improvements over 4.0.
    Post edited by mjc1016 on
