morph loader issue?
jim_24f6dba522jim_24f6dba522 Posts: 0
Hi
Im having some problems loading morphs in DS4.5pro using Genesis
I get this error
"Warning: Geometry did not match, failed to create morph."
At first I thought it was mud box but it happens even when I just export Genesis as an obj and then straight away try to load it back in as a morph?
cheers
Jim
  • niccipbniccipb Posts: 483
    Hi...
    It sounds as if you have exported the sub-divided mesh...
    When ever you create morphs for the Genesis figure you need to set the Mesh Resolution to Base and the Sub-Division Level to 0 before you export as an .obj
    You can find the setting in the Parameters pane with Genesis selected...
    Also make sure you do not add any sub-division in your modeler, or delete or add any vertices... the vertex count and order must remain un-changed in order to import a morph...
    Hope this helps... :)
  • jim_24f6dba522jim_24f6dba522 Posts: 0
    Brilliant! thank you so much.
    Jim
