Facial Morph sample?
Are there any code samples that show how to change Genesis facial expressions using the SDK?
  • dtammdtamm Posts: 126
    No. But what are going to want to do is iterate across all the DzPropertys on a node, it's object, and all the modifiers(if the modifier is a morph and use its valueChannel's) to find the DzFloatProperty that you want to drive.
  • rbtwhizrbtwhiz Posts: 2,179
    Porting the sample scripts located here to compiled C++ that uses the SDK rather than the script API should be fairly easy. The scripts are commented and show which classes are involved.
    -Rob
