Decoro
m_m_italym_m_italy Posts: 386
edited December 1969 in Hexagon Discussion
Hello to all.
I modeled this form.
I have to decide its use.
I hope you do not get angry hexagon.
It 'a work of patience.
That's it.
Bye
800 x 600 - 332K
  • m_m_italym_m_italy Posts: 386
    ......sorry.....
    1148 x 830 - 119K
    test corona.....
    800 x 600 - 605K
    ....test anello....
    Bye
    800 x 600 - 157K
  • edited December 1969
    Well, THAT'S a rather unexpected application!! :)
    Rather pleasing. Very nice!
  • RedSquareRedSquare Posts: 0
    A brilliant image. Not what I was expecting. :coolsmile:
    Thank you.
    Forgive the insistence.
    Here is a door candy (porta caramelle).
    Render W.I.P.
    Bye
    1148 x 828 - 435K
  • GhostmanGhostman Posts: 215
    Wow. That's beautiful m_m ! ;-P
    edited November 2012
    %-P
    Grazie Gost!
    Ho problemi con internet......
    Vedo male le immagini.
    E parlo brutalmente male la lingua Inglese.
    ....e non va il copia incolla.....
    Ciao
    :long:
    Post edited by m_m_italy on
    m_m_italy said:
    %-P
    Grazie Gost!
    Ciao
    :long:
    No worries mait! You're english is good enough. ;-)
    Ghostman said:
    m_m_italy said:
    %-P
    Grazie Gost!
    Ciao
    :long:
    Sorry.....ho problemi con Internet = internet problem
  • DaremoK3DaremoK3 Posts: 798
    Beautiful work, m_m_italy.
    Love the variations you created with the piece.
  • Proxima ShiningProxima Shining Posts: 969
    Very nice work!
    Thank you.
    Thank you very much.
    I have problems with the internet and with the site.
    I do not see the images.
    Happens to you?
    Bye
    :long:
    800 x 600 - 378K
    Very beautiful!!!
    DAZ site has problems since May, so I am not surprised that you have some problems with it. I do see images though, no problem. If that happens to you when you are in DAZ store, try Ctrl + F5 (forced refresh), sometimes it helps.
    Very beautiful!!!
    Thanks for the comment.
    Thank you for your help.
    The forum does not work.
    Negative.
    I'm sorry because I can not see the images posted by users..........
    You are not alone with this problem. Several people wrote about it in this thread. It seems that they did not find a solution yet, but try to check the thread regularly, maybe someone will find a way to fix it and posts it there.
    Post edited by Proxima Shining on
    O.K.
    Thanks.
    Ciao
    @m_m_italy Have you checked that your file permissions have not been corrupted or missing in the control panel ?
    For example .jpeg + .png + etc
    Edit: Durr! I'm a twit; He won't be able to see the screen grab.
    1024 x 766 - 156K
    Post edited by RedSquare on
    :blank:
    947 x 677 - 84K
    Hi - two members already mentioned that antivirus software Kaspersky Internet Security 2012 they have on their computers might be causing it after a recent update. Do you have this antivirus also?
    O'er, m_m certainly has serious issues. :gulp:
    420 x 360 - 20K
    Hi,
    You are absolutely right!
    Use this antivirus.
    I think this is the cause.
    I confirm.
    The problem is that I can not find solution.
    He also disable copy paste from google translator.
    La causa is Kasperski.
    Potrebbe andare peggio......
    Potrebbe piovere.....
    Bye
    It seems that updating from Kaspersky 2012 to Kaspersky 2013 should cure the problem - it worked for 2 forum members already. Also, one member added DAZ forum to Kaspersky white list and this helped also. You could also pause the antivirus for the time when you are browsing in the forum. Or just uninstall the evildoer alltogether and install another antivirus - that´s what I did with my antivirus when it crashed and nearly damaged my PC after an update.
    O.K.
    Grazie.
    Bye.
